    Default Garage walls bowed out
    How do you straten walls that are bowed,about three inches off the cement block.
    Thank you
    Default Re: Garage walls bowed out
    pull them in with a ratchet
    Otherwise known as a come-along ? .... was thinking the same.
    Curoius .... did the fasteners let go or the bottom plate rotted?
    The grage walls where bowed out ,do to a gas explousen in the neighbor hode.
    Thanks for the advice, i well give it a try i well let you know how i make out.
    Thanks again
    frank laskowski
