Results 1 to 10 of 10
    Default Rewiring a 7 arm wall sconce
    What kind of wiring do you use to rewire a 7 arm wall sconce? I usually stick with rewiring table lamps. The fixture is an antique and will be up to the owner to have it wired into the wall.
    MN
    455
    Default Re: Rewiring a 7 arm wall sconce
    I would have to guess "lamp cord" should work.
    I thought so too. I've checked other sites and they mention fixture wire. I'm just not sure.
    Lakeland ,MN
    356
    Fixture wire is smaller and easier to work around the bends in the arms. I believe you can get it a home center.
    Harry
    I know with lamp cord there are two wires, the ribbed side connects to the silver screw and the smooth side connects to the brass screw. Will I need to buy just one wire type? I wouldn't need a black wire and a white wire?
    Lakeland ,MN
    356
    Quote Originally Posted by AntiqueLampGal View Post
    Usually the wire has a see through jacket and looks the same at each wire. I have seen it two ways one used a copper color conductor and one used a silver color on the other wire. I have also seen with both copper or silver conductors but on closer examination of the individual wires the jacket one wire is marked with a stripe or has writing on it. I hope that helps
    Harry
    5,836
    I use 18 gauge THHN stranded wire I use white and black. Using white and black makes it a lot less confusing for the customer.
    If I use black and white wire, does it matter which wire goes to the screws on the socket? I appreciate everyone's input and have found it to be very helpful.
    5,836
    Black wire on brass screw white on silver. Brass screw is connected to center button in socket white is connected to threaded side of socket. You don't want the threaded side hot.
    Thanks for the advice. I think I'm all set now.
