    Nov 2009
    14
    Default finding a home builder
    I watch alot of home improvement shows and there a lot of contracter nightmares. How do you go about finding a honest experienced contracter to build a home and to do remodel jobs? Thank you
    8,002
    Default Re: finding a home builder
    Check these threads out. Lots of good info.
    http://advice.thisoldhouse.com/showthread.php?t=1346
    http://advice.thisoldhouse.com/showt...ght=contractor
    Feel free to ask further questions if they aren't covered in those threads.
    Nov 2009
    14
    thanks for the links it is all good advise except I have no one to ask that has had a builder or contracter to get a recommendation from.
    8,002
    IMHO, good tradesmen don't generally advertise to get work or stay busy, word of mouth is all they need. That being said, the best place to start looking is with trusted family and friends and coworkers. There has to be someone within your circle that has had at least a major renovation done. Start there.
    It would be best to find a new construction builder rather than a remodeling contractor because as similar as they may seem, a new build takes a different skill set and business acumen than renovations. It's not that tradesmen can't do both, generally they specialize in one or the other and problems usually occur for those making the switch the first few times.
    Contacting the local chapter of the National Association of Home Builders may provide leads to competent builders in your area. http://www.nahb.org/
    Considering that you're building your own home, one would assume that you'll be working with an architect or draftsman to come up with the plans. They should have leads to builders to suit your needs. Interior designers often have a list of contractors as well.
    Nov 2009
    14
    thank you for the info i thought that a remodeling contracter and a home builder should be different people also.
    Sep 2014
    Australia
    many question comes in our mind while finding a home builders. Here i will discuss on some important points.
    1. Firstly define your needs.
    2. Select on the basis of experience because experience matters.
    3. Look for sign of quality construction.
    4. Industry Involvement shows the membership for the time periods they are working.
    etc..
