    Oct 2008
    Default Switches to nowhere
    I just moved into a 50 year old house. Although some activate a wall outlet, there are a number of wall switches that don't seem to control anything. I also have some floddlights outside, that I can't find where to turn them on. My question is this, is there a way to trace what switches turn on/off, and to trace what will turn on the floodlights?
    1,884
    Default Re: Switches to nowhere
    Ah, every old house needs a few "mystery switches" that don't do anything.
    Wonder if someone removed some fixtures and covered over the boxes.
    Jul 2008
    central, IL
    12
    If you have an live wire tester you could run under and over the switch to see if you have a live wire in the wall. Maybe it's a weak way of checking, but if there's no juice, at least you'll know it isn't working.
    Did you try testing the wall outlets?
    Our Remodel Pictures: Hidden Content
    The deep South
    459
    Check in the attic for junction boxes with a dead end circuit . I found one in my home , and that explained my mystery switch .
    Do these switches have source voltage ? Check around in the attic , you might be surprised at what you turn up .
    6,016
    You might want to install a known good bulb in the flood and check switches again, you may have a bulb burnt out. Also check to see if it has a photo or motion detector.
    I have also seen people replaced switched outlets and forget to remove the jumper between upper and lower outlet.
