    Pennsylvania
    246
    Default Water Line location.....
    It is not a very good year for me.
    Stupid water heater leaks and water line that runs underneath garage slab decided to do Ole Fathful intimination.
    I'm working on water line issue right now and I've decided to run water line from the street underneath earth driveway and along the side of the garage.
    Could I run water line inside 2" diamter, 7ft long white PVC pipe?
    This PVC pipe will be approx 3 ft below top of earth driveway.
    The reason for that is I "may" put concrete or asphalt driveway sometimes next year or two. In case the line leaks, I could easily pull out the line rather than digging up good driveway.
    By the way........Go Phillies......
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
    1,661
    Default Re: Water Line location.....
    Not a bad idea, but I'd recommend using at least Schedule 40 pipe for crush resistance.
    Apr 2008
    Houston, TX
    62
    Sounds like a good idea...don't think there would be anything wrong with it.
