    Oct 2008
    Default electric baseboard noise
    purchased four 240 volt baseboard heaters. 2 of the heaters
    are 9ft/2000 watt and 2 are 4ft/1000 watt. at start up and cool down of the units, especially the 2 larger units, there is loud pinging/popping noise. all units are secured/installed as and where instructed. at this time would like to replace
    all units with models quieter if can be found.
    is popping and pinging inherent in all electric baseboard heaters?
    are electric hydronic baseboard heaters quieter than regular
    never had baseboard heat before. this is all new to me.
    thanks
    dak
    Default Re: electric baseboard noise
    There will always be a little bit of metal expansion noise when a baseboard heater goes quickly from totally cold to maximum hot ...... but it can be minimised if the grommets or plastic shields are in place between the heating element and the metal that it sits on. Making sure that these are in place and that the heating element moves freely will seriously reduce the noise.
    Having said that .... perhaps the problem may actually be caused by the thermostat.
    Recent electronic thermostat developments have actually totally eliminated this noise.
    Old style thermostats go on ..... stay on a while then go off ...... then stay off a while. This allows the element to swing from room temperature to very hot and back constantly. It also makes baseboard heaters the least comfortable of all heating systems.
    The electronic thermostats .... set-back or otherwise .... have changed that. The better of these devices actually check the temperature of the air every 3 seconds or so ...... and by proportional control modulates the outpiut.
    They are turning the baseboard on or off .... or leaving it on ...... or leaving it off .... every 3 seconds. The effect of this is ..... it doesn't get hot .... it just gets warm. If you do this constantly you could maintain any temperature you want and it never gets either cold or hot.
    So under normal circumstances the electronic thermostat causes the baseboard electric heater to stay warm ..... just the temperature necessary to keep the room at the set temperature.
    If it gets colder outside it will stay on a little more to maintain that temperature .... it will be slightly warmer but still constant.
    This process not only saves a lot of energy and keeps the room more comfortable .... it eliminates that expansion and contraction ping in electric heaters.
    The same heaters ..... with a better control and quiter as well.
    Just a thought
    Oct 2008
    canuk,
    thank you for your response. it was extremely helpful.
    thank you.
    sincerely,
    dak
