    Mar 2010
    7
    Default osb flooring rotted
    brother bought a cabin has been empty for seven years. has craw space no basement,osb board on floor rotted ,floor joices are pressure treated not aspot on them. craw space is damp,should we put vapor barrier down. and what should we use. thank you
    Mar 2010
    7
    Default Re: osb flooring rotted
    found out water heater and pipes bursted in the winter. after we did some research.
