Thread: Tung oil woes
    Apr 2010
    Default Tung oil woes
    I recently purchased and applied ****en's Tung Oil to a wide pine floor. I followed the manufacturers instructions to a tee but the oil isn't drying. It has been over a month. I tried several times to reach the maker but he never returns calls nor emails. I decided to scrub the floor again with just thinner to see if I could get the excess oil up but it still appears to be oily. The obvious problem with that is that it is tracking all shoes. What suggestions might you have?
    Apr 2010
    I'ma Maina!
    Default Re: Tung oil woes
    Two questions, was the wood new, and what did you use to cut the oil with?
