    Oct 2008
    Default Slipping Decorative Ceiling Beam
    There is a decorative (non-structural) beam that runs the length of our living room ceiling. The ceiling is about 12ft tall. The beam is supported by two carriage bolts driven through the beam in the middle of the room and into the attic. A steel cable is connected to the top of the bolt, attached to a turnbuckle and then secured to a rafter. Only one of the bolts has a turnbuckle and the cable on the other bolt is simply wrapped around a nail in a rafter and is no longer taught. A previous owner installed two ceiling fans dramatically increasing the load on the beam. Over time the beam has begun to slip creating a gap up to half an inch along the entire length of the beam. What is the best way to secure the beam and reduce the gap?
Name:	Livingroom beam 1.jpg
ID:	1742   Click image for larger version.
Name:	Livingroom beam 2 bolts.jpg
ID:	1743   Click image for larger version.
Name:	Beam turnbuckle 1.jpg
ID:	1744   Click image for larger version.
Name:	Beam bolt top.jpg
    6,047
    Default Re: Slipping Decorative Ceiling Beam
    What I would do is get some 4 X 4 angle iron and cut it in sections the width of the beam, say 4 or 5 at least. Drill holes in it for lag bolts. Use a jack post to jack the beam up and lay the angles on the beam and against a rafter. Drill and install lag bolts into the beam and into the rafter. Then you can remove the jack post.
Name:	angle plate.jpg
