Results 1 to 8 of 8
    Apr 2010
    Exclamation Updating an adding outlets.
    I have 100 amp pannel,I ran 15 amp arc switchwith 14 2 wire upstairs.Ran three outlet then to light switch.doing a three way switch with 14 3 wire then 14 2 to light.Then I spliced into hot wire coming up for a swith an light at bottom of stairs.Is this the correct way?
ID:	3424   Click image for larger version.
    5,940
    Default Re: Updating an adding outlets.
    I'm afraid you have some details missing, like the second 3-way switch. Could you do a drawing of what you have?
    I couldn't really follow you here but I did something up on the Paint program and let me know if that's it:
    And sorry that it is a bad picture, I was trying go as neat as possible
    Apr 2010
    Default i put pic up
    I put pic up
    Apr 2010
    Here is a drawing
ID:	3426   Click image for larger version.
    5,940
    Your drawing looks correct providing you followed the correct color code. By the way you could have controlled both lights with the 3-way switches. I omitted the grounds for simplification.
    Apr 2010
    Smile Re: Updating an adding outlets.
    Thanks for the help first time with three ways just want it to be right and code.
    5,940
    One problem you may have with code. The location of the outlets may require acrc fault protection and switches can cause them to trip.
