Results 1 to 8 of 8
    Apr 2010
    Default textured plaster walls
    Can I skim coat over existing textured plaster walls to get a smooth wall surface or do I need to tear out the plaster walls and replace it with dry wall? I am helping my daughter renovate her house and she doesn't like the appearance of the large textured surfaces.
    Default Re: textured plaster walls
    Yes, you can.
    May 2009
    Elyria, Oh.
    246
    A better and cleaner look would be to drywall over the plaster walls. You could use 3/8s or 1/4 inch drywall and not even worry about tearing out the trimwork and redoing it. If you are not a trained drywaller skimcoating takes a great deal of skill and a whole lot of work.
    Owensville, MO
    6
    Smile Re: textured plaster walls
    When doing our house we skim coated all the surfaces. But the important point to remember is to fix any cracks or loose plaster that is currently present, otherwise the skim coat will fail. The problem we had was tiny imperfections still showed (drywall would have given a better appearance). So we went over the skim coat with a really light texture to hide any imperfections we had. It looks great!!
    1,950
    The problem with veneering new drywall over the old walls is that it throws all the woodworkand trim in the room out of alignment with the new thickness of the wall. Door amd window jambs will have to be fitted with wooden strips to increse their thickness. Also, all outlets will now be in too far.
    Personally, I would go the skim coat of drywall route. I have an old friend who is slowly working his way through his whole house topping off the textured drywall that is so popular here in the Pacific North-West. His wife thinks he is crazy, but he, like I, was raised in "smooth wall" country and hates the textured look.
    Apr 2010
    Thank you for the encouraging replies, from one and all. I prefer to skim and not to veneer the textured plaster. I understand it will be alot of work to skim the plaster, and that the surface will likely not be perfectly smooth. Can you give me any recommendations on what to use as the skim coat and any additives that would make it bind better to the surface? I asked one dry waller (who did very good work on my home) for an estimate and he said it couldn't be done. I have some other names of dry wallers to call and I want to be sure that this project is doable and not just a pipe dream. Thank you
