    63
    Default Need Advice About Switching from Oil to Natural Gas
    Hi, everyone.
    I just received a direct mail piece from National Grid, inviting me to switch from oil to natural gas heat.
    I don't know much about what is involved with such a switch. I know I'll need a natural gas tank, but will that be able to hook into the radiators which heat my home currently?
    Thanks,
    Erik
    Default Re: Need Advice About Switching from Oil to Natural Gas
    If it's natural gas ( NG ) there is no tank involved -- it's piped to your home.
    Other than oil the only other fuel that requires a tank would be propane (LP )
    As for you radiator heat --- the natural gas would replace the oil as fuel for the boiler.
    It would require to retrofit the boiler ( if it can be ) --- removing the oil burner components and replace with natural gas burner components.
    Jul 2009
    Northeast
    661
    I looked into changing from oil to gas a couple years ago and some gas companies will give discounts on equipment. Ask them what they have to offer in that respect.
