Results 1 to 1 of 1
    Post How to remove old well tank?
    I just purchased an older home that was switched from well water to city water but the old well tank is still attached to a "mystery" pipe (more like hose) that goes through a small hole in the basement foundation. The tank seems full?!?! How do I disconnect and get rid of this thing? There is no interior plumbing attached but there is also no drain valve. The picture is horrible, I'll be posting better ones ASAP.
    Thanks!!!
