    Oct 2008
    Default Drainage and grading dirt at low foundation
    I have a problem with water coming up against my house during large storms because my neighbor's house is about a foot higher than mine. He is about 15 feet away. I wish to redirect the runoff between the two houses toward the street. I want to accomplish this with a perforated pipe french drain between the houses with outlet closer to the street, but more importantly, I need to grade the dirt from my house toward that drain. I need to slope it and raise it at least 1 foot higher at the wall. My issue is that I have to raise this dirt level above the foundation line up about 2 bricks at least. (The water has gone that high.) There are weep strings coming out of the mortar joints where the bricks meet the foundation. I am not sure if all I need to do it put lots of tar or roofing cement along this joint and stick plastic sheeting to it to seal it before backfilling, or if the strings have to show always. Any suggestions on sealing this joint would be appreciated.
    Oct 2008
    Chicago
    19
    Default Re: Drainage and grading dirt at low foundation
    No one else has answered so I hope no one minds if I comment
    Yes, those wicks need to be exposed - they wick the moisture from behind the brick that's between it and your structure. If they don't drain out, they'll drain in.
    lower your ground, don't raise your water. Ground level should never be above your sill. There should be 8 or 10 inches of foundation showing above ground.
    There should be a swale between you and your neighbor.
    May 2010
    I have the same problem, and don't want to keep the grade it requires to maintain propers drainage. Our yard is at 20 degrees for the 11 feet to the neighbors house. I will bury about a foot and a half of foundation and a few rowes of brick, redrill the weep holes for the wall drafting. All I need to know is what would keep the water out. Like the original post, I am thinking roofing tar with tar paper over that. Once its waterproofed and my yard is level, I will redrill/cut thier weep holes. My foundation is exposed a foot so really I will need like a 25 degree and more dirt work than what Im interested in. Any suggestions?
    Mar 2011
    5
    Our yard is 20 degrees for 11 feet to the neighbor's house. I will bury a foot and a half of the foundation and a few brick Rowes, redrill the drain holes in the wall of writing. All you need to know is to keep water out. Like the original post, I'm thinking of tar with tar paper on it. Once your water test and my garden is level, I'm going to cut drainage holes.
    Aug 2009
    5
    Quote Originally Posted by richardmarshz View Post
    what did you guys end up doing?
    I have a problem area in my front yard where there was landscape paper and lava rocks into the first row of bricks and without going into the bricks the ground would slope a bit upwards from the house. There are various shrubs and trees who's roots would have to be totally dug up if you were to slope downward from the house. It would be a very destructive project to slope away from the house WITHOUT going to the "brick line". The driveway even runs right next to this area and therefore any sloping down you do without going to the brick line will pretty much make the area into a ditch. We are re-doing the area but realized how far up the ground has to be into the bricks for this to work. Any suggestions?
    Worried about potential water/moisture issues and even termite issues but doesn't look like there are any great solutions without having to spend big money.
    2,636
    Based on what is on the other side of the foundation wall it may be permissible to waterproof and fill to gain the away-sloping grade you need. I never cease to be amazed at how poorly some homes are sited when 1/2 of 1% more of the initial cost could have solved the problem when building them. Essentially you do not want any dirt as high or higher than any wood on the other side, though you can extend waterproofing above this so long as it's sealed to the house. It is always better to regrade water away from the house than deal with it going that far even if it's going to cost. Do everything you can to minimize water near the house first, then see whether you still need more help. Moisture near the house not only invites termites and rot, it can also destabilize the footings or undermine a slab. This is why you approach this grading and drainage first and foremost, then deal with what's left afterward.
