    Oct 2008
    Default redoing stair treads
    When we ripped ancient carpeting off the stairways in our home, expecting oak treads, we found cheap pine treads. My contractor says they cant be sanded and stained, you cant just replace the treads,because they are cut into the molding, and that it is expensive to rebuild the stairs.
    Are there any laminates or caps for the existing treads to make them look nicer? The landing below is ceramic tile, and above is pergo, so I dont really want to carpet them. We tried painting and it just doesnt look good.
    any suggestions?
    5,821
    Default Re: redoing stair treads
    First I would have to ask why they can't be sanded and stained or dyed. Second a faux wood grain finish might be a possability, that's been done for hundreds of years.
    I'm wondering if the treads and stringers were covered with carpet and if the treads are solid pine and not plywood .... in other words rough ins meant to be covered.?
    Yep
    http://www.pergo.com/US_Install_Performance.aspx
