Thread: Fiberglass tubs
    Oct 2008
    Default Fiberglass tubs
    We are starting to remodel our bathroom. I want a one piece fiberglass shower/tub. I hear that I will need to put concrete or sand under the tub or it will crack. True??? Help!!!
    7,240
    Default Re: Fiberglass tubs
    Depends on the tub and the manufacturer, sometimes there is a styrofoam support, sometimes not. If there is no support of the bottom of the tub, then yes, you mix up a batch of mortar or stucco (the premixed bag is perfect ) to a thick consistency and pile it under the central mass of the tub, then you set the tub in place and "shimmy" it to settle it into the mortar base. Let the mortar cure 24 hours before stepping into the tub.
