    Oct 2008
    Default Hot water radiator not heating
    I have recently moved the radiator in my bath room and now we can't get it to heat. I bleed it I got hot water but it did not come through the radiator it came up the pipe right below the bleeder. I don't know if the radiator needs turned around or if that is even a problem. I need to know if there is a in line and out line for the radiator and if so could that be the problem.
    6,053
    Default Re: Hot water radiator not heating
    Yes, there is an in and out line or feed and return and it sounds like you have them reversed. You get hot water but you are not bleeding the air out of the unit.
