Thread: Fundation Walls
    Default Fundation Walls
    When I watched the latest show on the Weston project, I saw that they were putting a waterproofing membrane on the foundation walls. This is the first time that I have seen them use a membrane on the Superior wall product. Was this something necessary for this project or does this product need this?
    Thanx
    Memphis, not Egypt
    183
    Default Re: Fundation Walls
    I believe this is standard now fo basement construction plus I think I heard them mention the watershed as there is a creek very nearby. If you want a dry basement the membrane and the french drain along with some work under the basement floor are a must do.
