    Default Treated Lumber Used Inside
    Is it dangerous to use treated lumber (plywood purchased at a home store within the past 6 months) inside to place wood cabinets onto a concrete slab floor?
    The info from the internet says okay to use as long as food prep not being done.
    Someone else I know is all freaked out that I want to use it to keep any moisture from wreaking the cabinets?
    Anyone else?
    Thanks
    6,103
    Default Re: Treated Lumber Used Inside
    I think a cheaper and more reliable way to go would be with something like adjustable corner brackets It would keep the cabinets off the floor, allow air circulation and make leveling the cabinets much easier.
