Results 1 to 9 of 9
    Oct 2008
    Default One furnace or two?
    I recently purchased a four-square house built in 1908. The house is 750 sq ft upstairs and 750 sq ft down stairs with a full basement. I am trying to determine if I should put one furnace in to heat the entire house or if I should put one furnace in the basement for the 1st floor and one in the attic for the second floor. Does anyone know if there is a way to determine which option is best?
    Thanks!!
    Maryland
    1,903
    Default Re: One furnace or two?
    Your house is certainly small enough to be heated by one furnace.
    The first cost for 2 furnaces will be much larger than one furnace sized to heat the whole house. I guess where to run ducts is an issue. What type of system do you have now?
    Oct 2008
    There is currently one furnace in the basement that heats the house. The duct work is in good shape and is rigid metal.
    Maryland
    1,903
    I would go with one in the basement hooked up to the existing duckwork. Basically switch out the old unit with a new one.
    Oct 2008
    Thanks ed21! I thought the same but mine was uneducated. Thanks again for the help.
    Ditto to what ed21 said .... if you want look at zoning the first and second floors.
    Oct 2008
    With regards to zoning the first and second floors. Will this allow me to have a separate thermostat for each floor? Also, what can I expect to pay for adding a zoning option?
    Yep ..... you will have seperate thermostats for each floor.
    Costs will depend on the brand ... model .... contractor ... region.
    Iowa, Quad-Cities area
    129
    Zoning will cost around $4,000. It works beyond belief.
