Thread: Plumbing
    Default Plumbing
    We bought an old house built in 1930. It is hooked up to a septic tank. The plubming is very rusted and we need instructions on how to replace all plumbing in the bathroom. HELP please. If you know how we should proceed it would be very helpful. We realize it will all have to be replaced. Never done this type before. Thank you.
    5,793
    Default Re: Plumbing
    If you are talking about the plumbing hooked to the septic system which is waste plumbing, unless it is leaking there is no real need to replace it.
    If you are speaking about old galvanized supply plumbing the th fixtures, there is no need to remove it all. Disconnect at the lowest point to drain it, then disconnect the connections to the fixtures and as much as you can get to. To remove it all will require rather extensive removal of walls, floors or ceiling sections. Once it is disconnected and drained you can run new PX tubing as a replacement. Because PX is flexible you can feed it through walls and ceilings with minimal tear out.
