    Apr 2010
    Default anchoring into cinder block wall
    Some people told me to use tap cons but I could not find any for the size screw I need to use. Putting up handrail. Found plastic anchors that can be used for concrete, cinder block, dry wall. Has anyone used a plastic anchor for a cinder block wall? Will be using a hammer drill.
    May 2009
    Elyria, Oh.
    Default Re: anchoring into cinder block wall
    Thy will work just fine.
