Thread: mold or algae
    Oct 2008
    Default mold or algae
    On the north side of our home we have a green mold or algae. If you use bleach it will come off but it comes right back in a couple of weeks. This mold or algae is spreading up the vinyl siding and across the cement block on to wooden decking and on to metal siding of shed. What is this and how do I fix or get rid of it????
    Oct 2008
    56
    Default Re: mold or algae
    Molds have to have an acidic (low) ph for spores to grow. If you have moss on the ground on that side of the house, try lime on the dirt, heavily. Also, condensation is a source of moisture that encourages mold growth. The warm side of a surface will have condinsation which might be an insulation issue.
