    Unregistered Guest
    Default Where to obtain this tool and screws
    I saw a show that used a 3 legged device to insert a screw through a rug into the wooden floor to a certain height and then it could be used to break off the top of the screw. This allowed the repair of loose or creaking wooden floors which had rug over them. What is the name of this device and where can the device and these special screws be bought?
    thanks,
    Mike
    6,045
    Default Re: Where to obtain this tool and screws
    Unregistered Guest
    Talking Re: Where to obtain this tool and screws
    Your local Ace Hardware store either carries them or can order them for you. First time be sure to order the kit that contains the setting tool, as just the screws themselves are also available in similar quantities without the setting tool.
    http://www.oberry-enterprises.com/
