Thread: Hardwoods
    Mar 2010
    Default Hardwoods
    Hello,
    We currently have a 1960s house with a hodgepodge of flooring....parquet floor, carpet, and pergo (under which is linoleum), all installed on a (mostly) concrete subfloor. There are sections of the subfloor that are particle board and plywood where an addition to the home had been built in the 70s but otherwise the majority of the floor is concrete. In any event, the subfloor is not level in many places and humps and bumps are visible.
    We want to rip everything out and put down hardwoods. We recognize that proper floor prep and leveling will be essential. However, we are getting very conflicting information as to the types of wood we should install. Some flooring companies recommend engineered wood glued to the concrete and others recommend short boards of solid hardwood glued to the concrete. We're getting so much conflicting advice that we're not certain as to which would be a better product to install onto concrete. We'll have a moisture test done first, and assuming everything is ok, what would you recommend?
    Thanks
    7,589
    Default Re: Hardwoods
    I personally recommend engineered wood floors over slabs and leave solid wood floors for raised foundations with wood subfloors.
    Here's the thought. Concrete absorbs moisture during the wet season and dries out during the dry seasons. While this is normally a minor thing, some locations can experience severe climatic changes from season to season, resulting is radical moisture differentials. The problem with permanently affixing the flooring to a slab is expansion and contraction issues. This is why a "floating" floor is IMHO a better choice. Secondary benefits are that a floating floor is faster, easier, and cheaper to install than a permanently affixed floor, especially over concrete. There is also the issue of clearances under doors throughout the house when factoring in adding a plywood layer over the slab, plus the flooring itself. None of these issues generally exist with a floating floor.
    This is not to say that a raised foundation/wood subfloor doesn't experience moisture swings, however, generally, most raised foundations don't have sub area moisture issues. If you have a raised foundation and you have moisture issues, then you need to address the moisture before you address your flooring.
    With a wood subfloor, it is perfectly acceptable and reasonable to mechanically install the flooring - nailing to subfloor. The only caveat is that the flooring be rated for mechanical fastening, which most solid wood flooring is. Engineered flooring usually needs to float.
