Results 1 to 10 of 12
    Mar 2010
    7
    Default River Birch Roots Taking Over
    We have 2 large river birch trees in our backyard. The roots are coming to the surface and beginning to take over the yard. It is killing the grass in areas and we are afraid the roots are going to spread under the house and driveway and cause problems. What can we do to get our yard back and keep the trees. We really like them. Thanks!
    1,387
    Default Re: River Birch Roots Taking Over
    Nothing. Addig soil to smooth things out helps but only a temp help.
    Mar 2010
    7
    So the long term solution would be to remove the trees?
    1,387
    Become one with the roots. These are pretty trees, perhaps a large planter and some mulch or just mulch.
    May 2009
    Elyria, Oh.
    246
    Yes Remove the trees. If you replant consult with your local nurseryman or arborist to make sure the trees you replant don't shade out the grass or have roots that come to the surface. Mountain Ash is a nice species with tiny leaves that don't have to be raked, light shade so grass can grow and a nice specimen tree.
    Mar 2010
    7
    These are beautiful trees and we would like to keep them, however they are about 40 feet tall now and some of the roots are out of the ground nearly a foot high and starting to spread everywhere. Our daughter trips on them when she's out there. Not to mention our grass is starting to be replaced with dirt spots with tiny roots from the tree.
    Mar 2010
    7
    Any other possible solutions?
    Mar 2010
    31
    I just finished a quick on line check on river birch and it looks like it would be best to remove the trees. Though beautiful they pose danger to your house--a strong storm and shallow roots could wreck havoc to your roof. Roots spread out up to 3 times the diameter of the tree thus threatening yours and your neighbors driveways and sidewalks. Not sure what it would do to your house foundation. But it's a decision that maybe a local arborist could help you make.
    Nov 2013
    If we just cut the exposed roots will it kill the entire tree. It's pushing up our patio slab.
    8,002
    Quote Originally Posted by Sprescott View Post
    Depends on the tree, surface roots are generally caused by surface water, such as daily/weekly watering of lawns. Topical watering draws tree roots to the surface, whereas deep watering promotes tree roots to go deeper and fend for their own water.
    Know that cutting roots at the edge of your patio will only stop what is under the patio already, it won't stop the root from regrowing, nor will it stop other roots from traveling under the patio and causing damage. Worse still, is that trees too close to the house can cause foundation issues too, so if the tree is already causing serious damage, it's time to take it out, eradicate the root system, and plant something that won't be invasive or damaging to the home.
