Thread: Mystery Wall
    Mar 2010
    Exclamation Mystery Wall
    My fiance and i are moving into my great uncles who had passed away years ago. The entire house has the dark brown wood paneling, except for in the upstairs room. The walls in this room are not flat or smooth, they aren't even "hard". My aunt mentioned something about "oil clothe", i've never heard of it and was wondering if it is possibly to take down the "soft" wall and put up drywall to make it look better. Thanks
    1,950
    Default Re: Mystery Wall
    Omnarg,
    Sounds like you might have a product we used to call "beaverboard". It is a very fibrous wood product. It was a cheap way to cover walls. It could be painted and look a lot better than a totally unfinished attic.
    At a minimun, I would open an exploratory hole and see what is behind this board. My guess is that you will find little or no insulation - all the more reason to tear it down.
    If it is beaverboard, it is very easy to tear down. It has very little structural strength, readily breaking apart.
    Omnarg,
    I've seen this stuff used in some really old homes around these parts. If it's the same stuff I'm thinking of, it has insulative and sound deadening properties. My guess is that it was a cheap way to cover the walls and get a little insulation at the same time.
    My personal recommendation is the same as Ordj's, remove it, insulate, update wiring while the walls are open, then install drywall. Good luck with your project. Keep us posted on your progress, we're here if you need us.
    Quote Originally Posted by Omnarg View Post
    Oil cloth was an old time material used for rain coats and tarps ---- generally made from canvas , jute , burlap.
    At one point a design was printed onto a sheet of oil cloth along with a varnish coating and used for floor sheet goods.
    If it was oil cloth on the wall you be able to tell since it would be soft and flexiable --- kinda like a sheet of vinyl or linoleum.
    Otherwise it may be what the others have described --- another name is Homasote.
    6,115
    Oil cloth was also used for table cloths.
    Geez Jack that's right --- forgot about that.
