Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Default Re: Ceiling Fan Wiring help
    I did also assume that connecting both the fan and light wires to the hot (red) would do the trick. but then I have a black wire coming from my ceiling that is attached to nothing? I can just cap that off? Seems odd that it's there for no reason.
    thanks
  2. #12
    5,798
    At the ceiling, do you have two 3cond plus ground and one 2 cond plus ground or do you just have two 3 cond plus ground?
  3. #13
    i dont know what a cond is.
    When I use my tool to see if electricity is present, both black and red are live. the white doesnt give me anything. dont know if that helps.
    by the way, i just tried connecting fan and light to the red, and neither works.
  4. #14
    5,798
    Do you have two cables at the ceiling with a black conductor, a red conductor, a white conductor, and a ground
    Or do you have two with red, black, white and ground and one with black, white, and ground?
  5. #15
    finally figured it out. connected fan and light to the red, and just capped off black by itself. (i had forgetten to connect another piece before, thats why it wasnt working then)
    thanks for all thehelp
