Thread: Smelly plumbing
    Default Smelly plumbing
    My house was made in 2003. I keep getting a bad sewer smell from my shower and my tub. What could be causing this? How do I fix this?
    Marc
    443
    Default Re: Smelly plumbing
    Smelly drains can be caused by a number of factors: a) there is always a "P" trap, an "S" trap or a "Drum" trap with a little water in it in each of these drains to prevent sewer gases from backing up from the main sewer; if the vent system is inadequate, or clogged, enough air can't get into the drain & the trap water will be pulled out of the trap, allowing smelly gases to enter the bathroom.
    b) sometimes it's not the bath/shower drain at all, but the MAIN DRAIN that has stopped up; c) sometimes the drum trap or other trap is clogged & has to be cleaned; there is a screw-off cover to all these traps; hair getting down the bath/shower/vanity drains is the bugaboo of all bathroom drains; it clumps into a gooey mass, decomposes & smells & it is notorious for clogging bathroom drains.
    For further discussion & tons of other possibilities, Google "smelly shower drain" to get numerous variations.
    Also Google "bathroom drain piping" or "tub drum trap", or "bathroom drains" (Google with & without the quotation marks) to try to get diagrams of these systems so you can picture in your mind how they work.
    Ohio
    17
    Sometimes (rarely) its the vent stack that is at fault. If it's causing too much suction, it is taking that "weir" water (the stuff left it the P trap) along with everything else and allowing the "sewer" smell to come up. If it is clogged (leaves, debris, etc.) it will also not draw properly.
    Just another thing to check.
