    Oct 2008
    10
    Default Staining floors that have been previously tiled
    My kitchen floors are heart pine which were tiled about 45 years ago when a "tar" was used. I have heard that this "tar" will interact with the stain and could create black spots if I sand, stain and seal the floor.
    Oct 2008
    West Virginia
    6
    Thumbs up Re: Staining floors that have been previously tiled
    Hi, I found this stuff called GOOF OFF that removes the glue and does not affect the wood. The only pain in the butt is the scraping but its well worth it. I am still trying to figure out how to get the white marks off my hardwood floor that had tile on it first
    Good luck and hope it goes well
    Oct 2008
    Default Re: Staining floors that have been previously tiled
    That black, tar-like substance was under my linoleum, also. I soaked it with water and DAWN dish soap. It came up with the $30 sc****r from Home Depot, found in the flooring department. Let the dish soap work for 10-12 minutes, but sc**** wet, do not let it dry out. Black stuff gets soft, then hard. Will re-soften if you re-soak.
