    Oct 2008
    Default Painting previously stained and sealed Canadian Pine Hardwood Floor
    Question: what is involved in painting over a previously stained hardwood floor (about 33 square ft)? -- time, expertise, tools, type of paint, process --
    details of situation:
    We have a small (approximately 33 square ft.) powder room in which we installed stained canadian pine hardwood flooring. This was done by a contractor while we were out of the house. when we returned, we found the that the stain was the wrong color/shade and the contractor vanished.
    we are interested in a "chocolate brown" color
    we considered re-staining the floor, but, even with the small square footage, it is prohibitively expensive. Also, it seems that we may not be able to get a good color-match even if we did so.
    That said, we are looking into painting the floor and are getting conflicting advise and scenarios of how to do it and how long it will last, etc.
    the floor company said that, though they do not paint floors, we did not have to sand the floor down to the wood and then fill cracks, prime, re-sand etc. He said that all we had to do was to lightly sand the protective top-coat (some kind of water-based product) to "roughen it up" enough to bond "porch" paint. We would then lightly sand and add some protective coating over that.
    We would greatly appreciate some solid advice from someone with experience in this area.
    thank you very much.
    MN
    455
    Default Re: Painting previously stained and sealed Canadian Pine Hardwood Floor
    Like what was told to you before the floor has been coated with a protective wear layer. In order to apply another coating the floor has to be sanded to break this wear layer coating.
    Paint doesn't wear well as a floor coating without being coated with a protective wear layer. There is no way to be sure if painting will work.You may have to sand right down to the bare wood and restain with a new protection coatings applied.
    In my opinion if you can live with the color do it otherwise it will be a lot of work and cost for something that may not last long.
