    Oct 2008
    Default 1940 house wiring
    I bought a 1940 built house with two prong outlets. I'm replacing a celing fan the previous owner installed. There are only two wires coming from the celing outlet and both are black. The non-contact voltage tester I bought for $10 lights up on both wires. I noticed this voltage tester lights up on both sides of most receptacles in the house.
    Do I have a major problem or is this normal? How should I select a wire for the ceiling fan for hot?
    Thanks a lot.
    6,053
    Default Re: 1940 house wiring
    It is quite common to get false readings with non contact testers. They light when ever they see a change in the magnetic field. Use a voltmeter and test to ground or you can use a receptacle tester by attaching the wires to the prongs.
