    Oct 2008
    Default metal roof color
    I have a sandstone beige house with white trim.What color should I paint my metal roof?
    Oct 2008
    Default Re: metal roof color
    Maroon would be perfect.
    Oct 2007
    175
    Do not paint metal roofs! They either have a baked-on finish or are anodized aluminum that is good for the life of the roof - any paint you can apply will not hold up any length of time.
    Maryland
    1,545
    The finish doesn't necessarily last the life of the roof.
    Oct 2008
    56
    A darker version of the sandstone biege is what I would say. It really depends on your own tastes. My reason is, nuetral is safe and timeless rather than trendy. If you're painting your roof, you probably only want to do it once.
    Be sure it's clean and use an acylic red oxide primer (for steel ). If there is any rust present, look for a product called "Ospho" and follow the directions. This is a rust prohibitive primer for steel. An acrylic primer is okay for aluminum )For the finish use a semi-gloss acrylic latex. It has more flexabilty than oil paint.
