Results 1 to 10 of 13
Thread: messy painting
    Jul 2008
    8
    Default messy painting
    Well, I thought I was a fairly good painter...However, my beautiful 72 year old house with original trim tells another story! I guess all my other projects involved painted trim! Any tips on cleaning up the little edges that bleed under the paint tape on the trim and straightening up the cove ceiling edge? Thanks!
    Sep 2008
    25
    Default Re: messy painting
    Nothing sucks worse that painters tape that fails. I have no idea what type of paint that you were using ( water or oil base) but the best thing to do is to get it off your trim before it fully cures. I am guessing your trim is stained and finished. If you used waterbase paint you might be able to take a plastic razor blade and get the bulk of the paint off or if is just a little take a rag soaked in really hot water and rub to get the rest of it off. For fine detail ares you can take the rag and wrap it over the blade of a putty knife and use the sharp edge of the putty knife to force the rag in tight areas. If your trim is finished with high gloss finish you have to be carefull what you try to get oil base paint off with because you will dull the finish, if your trim is not high gloss you can try a rag with paint thinner, lighter fluid or goof off on it. Do not rub hard on the finish it may take 10-15 seconds before you see the paint starting to break down, if you rub really hard you could destroy the finish on your trim
    Pennsylvania
    246
    My2¢... I have used local hardware store and house painter’s tapes and they are horrible.
    Now I use auto body shop masking tape / painter tape. They're the best on the market. The bad part about it.....don't leave it on for more than a day or two because they're SOB to remove.
    By the way, you can buy it from auto body / paint supply stores. Look in the phone book, you'll find them.
    One more thing, if you see "auto body tape" inside local auto parts store.....run away...they're not the same if you buy from auto body /paint supply store.....trust me on that....I've been doing this for years.
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
    8,004
    Quote Originally Posted by BigWalt View Post
    Tape and roller/brush painting are a bad combination, PERIOD! It only works if you know how to do it, even then results are mixed. The best advice is to use a good quality brush such as a Purdy or Baker. A sash brush (angled bristles ) works the best for detail painting.
    Pennsylvania
    246
    That might be the truth but I do have good results with auto body tape...
    I agree with paint brush but not many people know how to use correct brush.
    8,004
    What works better than tape is a flat metal edge, such as a drywall taping knife. You move the edge along as you are painting, cleaning the edge as necessary as well as cleaning up any bleeding that occurs before it has a chance to set. Fresh latex will wipe right off with a wet rag.
    Denver, CO
    666
    I ain’t no painter.
    But I was recently accused of being Anal Retentive, OCD and just wayyyyyyyyyyy too type “A”.
    Anyway, I like to learn new things, do them well and do them right.
    I work in “the trades” and I like to know the tricks of other trades.
    I met a painter years ago who taught me a bunch of painter secrets.
    One of those “tricks” was to shoot a bead of “painter’s latex” into all joints were wall meets wall or ceiling or wood work. A small bead cleaned off with a finger and cleaned up with a water soaked and rinsed rag.
    This gives a defining line to cut-in your paint to.
    8,004
    Quote Originally Posted by kentvw View Post
    I ain’t no painter.
    I too subscribe to the "bead of caulk" theory, however as suggested above, if the trim is stained against a painted wall, then the caulk thing doesn't work quite as well. I have purposely waited for the original poster to add commentary before delving into the caulk zone vs. cutting in methodology.
    Jul 2008
    8
    Thanks everyone! The original poster is overwhelmed!
    I've never heard of painters caulk but look forward to the "caulk vs. cutting" commentary. I suspect, however, if it's anything like the caulk I tried to do on my tub, I'll need more practice before attacking the dining room! I've tried a straight edge before, though not with this project, and not had much luck. I've also not heard of auto paint tape but that's an interesting option. I still have 3 rooms, two stairwells and a hallway to go so perhaps I can try all your tips and figure what works best for me.
    A little more detail: it is the original trim: gum wood that I don't believe has had anything done to it since the original stain and varnish (or whatever they did in 1936). Also, the coved ceiling does not have the edge that others I've seen have. It is just smooth to the wall. I'm using a latex paint from my local hardware and a Purdy angled brush. Also, this is a project that was started by well-meaning, but messier than I, friends some time ago while I was at work. So, I've old mess and my new mess.
    8,004
    Ok, the caulking trick is to put a small bead of caulk in the corner of whatever you're trying to paint. The caulk fills any gaps or roughness in wall texture and gives a "glossy" smooth surface for the paint brush to glide on. When the brush doesn't have to get into pits and pockets, it can release it's paint quickly and cleanly with fewer strokes, making painting faster and easier and the finished product more professional. Painters caulk is a latex caulk that is very easy to use, though as will all caulk, it takes a bit to get the hang of the application technique. I would say that by the time you get to the end of a 10' wall that you should be caulking like a pro if you follow these few simple tips.
    1. Cut a small hole at an angle in the end of the tube 1/8" or less in diameter.
    2. Use a good quality caulking gun. If you're not sure what that is, go to a paint dealer (not Home Cheapo ) for advice on what the pro's are using. A good gun is not necessarily an expensive gun, but there are features that make all the difference.
    3. With latex caulk, have a wet rag with you. You want the rag soggy, but not dripping, don't wring it dry or it won't be of much use.
    4. When applying the bead, use a small, continuous bead. Don't worry about trying to fill all the gaps with the first application, the key here is to use small amounts of caulk. Only apply caulking for as far as you can comfortably reach.
    5. Wet your finger on the rag and then press it into the caulk and drag it along with a slight pressure. Don't allow the caulk to build up on your finger, if it does, stop, wipe it on the rag, and continue. Take short strokes to prevent build up on your finger. When you're done, go back to the beginning and pull your finger along in one fluid stroke.
    6. Always lift your finger while in motion. This prevents the caulk from sticking to your finger and pulling out of the joint or having pull marks.
    Painted surfaces against stained material, such as the trim you described, you can use a clear, paintable caulk ( NO SILICONE ). The nice thing here is that normally stained trim isn't caulked to the wall because you'd see the caulk. By using clear, anything that gets on the stained material will be invisible, the gap and wall will get painted, making the transition between the wall and trip seamless.
    If you don't want to caulk stained trim, still no biggie. You simply load your brush as described in a previous post and place it 1/4" or so away from the trim. In one motion apply pressure and start your stroke. As the bristles bend you use motion and wrist position to guide the bristles up to but not touching the trim and continue your stroke. Because of the texture on the wall you'll likely have to stroke in both directions. To do that, make your first stroke and stop, lifting the brush while in motion. Now turn the brush around and stroke back in the other direction. This will fill the pits and pockets from both sides. At this time you will clean up any goof marks with a damp rag - not soggy, but not wrung dry either. Cleaning up wet paint is far easier than going back after it has dried. If you slip and take paint off the wall you can carefully retouch that spot, no biggie.
    Now, if you're doing two different sheens of paint OR different colors of paint, you'll use the same technique described above, only you'll want to paint the smallest surface first because it's more difficult to get the paint where it's needed without getting it everywhere else too. If the paints you're using are just different sheens (gloss/semi-gloss on trim, flat on wall ) then the excess paint can be left to dry. If using different colors, then the color should be cleaned up as much as possible and allowed to dry completely before continuing with the second color on the larger surface. The second color will be cut in in the same manner described above.
    That's all there is to it. As with the caulking, painting is a learned technique. It won't take any time at all to develop a style and rhythm that works for you and produces professional results. You've already got a good brand of brush, as long as it's taken care of it should provide many years of service.
