    Oct 2008
    14
    Default Help on Style of Home? Northern NJ
    Thanks in advance for the help, this is my first post. The home was built in the late 1920's or early 1930's I am told. Could it be a colonial (everything is quite symmetrical) or is it too small?
    bottom floor is an open plan with the stair case in the center rear of the house. The stair case is split and turns 180 degrees and continues to top floor hallway.
    Any ideas would be appreciated. The house is in Northern NJ.
    Thanks
ID:	1662   Click image for larger version.
    Default Re: Help on Style of Home? Northern NJ
    Hi,
    Flooring is one of the important things that decide the beauty of your home. The colour, style and material of flooring define the style and atmosphere of your home. There are different types of materials available in the flooring section. It is your duty to select the exact one that gives an extra look to your home.
    1,383
    It is a period house in the "English Cottage" mode. Sometimes called a "storybook" cottage.
    S_M
