Results 1 to 10 of 14
Thread: Slab Leak
    Oct 2008
    5
    Default Slab Leak
    I live in Indiana where many homes are built on concrete slabs with the plumbing included in the slab. Most builders use copper piping for the water but after years of hard water use, these often develop small leaks. I can hear a faint sound of water running and my water bill has gone up in the last month. There is no sign of water anywhere inside or outside, so the only thing I can think of is a leak in the concrete pipe somewhere in the slab. Is this a DYI project possibility or no choice but call a plumber? Is it cheaper and more cost effective to fix the leak or is replumbing a better option. Seems more and more people are experiencing this in the Midwest.
    West Jordan, Utah
    84
    Default Re: Slab Leak
    The leak may not be in or under the slab, you will be able to hear a leak in the service line out side of the house too.
    First thing you might try .....
    Look at the water meter to locate the flow indicator to see if it's showing water flowing without anything open.
    A mechanical meter there will be some sort of spinning pointer .... possible star or triangular shape.
    On an electronic digital meter there will be a section of digits indicating of flow.
    If your unsure what to look for ....... turn on a faucet to see the flow indicator on the meter.
    Once you have found the flow indicator and if it does show a flow without anything running....turn off the angle stop valve to the toilets and check the flow indicator to see if it stops.
    There are occasions where the fill valve in the toilet tank are the culprit.
    If the toilets aren't the issue .... try turning off the main water shut off to see if the noise stops.
    The deep South
    459
    If you hear water leaking , then it should show up somewhere .
    Most leaks under the slab make themselves known in an unpleasant way . My late in-laws had one and it came up and soaked the carpet . A plumbing company came in with a leak detector and went right to the correct spot .
    West Jordan, Utah
    84
    Once you find the flow indicator on the water meter, if it shows a flow, I would turn off the main shut off valve first, if the flow doesn't stop the leak isn't inside the house and there is no need to check the toilets. If the flow stops then check your internal plumbing fixtures.
    Quote Originally Posted by Blake View Post
    Same thing just in reverse order .
    West Jordan, Utah
    84
    If the leak doesn't stop when the main valve is shut off there is no need to check fixtures that are not leaking. Work smarter not harder.
    That would be the conclusion.
    Memphis, not Egypt
    183
    YES as you should clearly see by now you should call a plumber. You do your job and let them do theirs.
    Oct 2008
    5
    I looked at the water meter and it is barely creeping up, but it is moving just a hair. There is no sign of water anywhere either inside the house or outside. There's not even any condensation on the floor or anything. Outside, there are no damp spots on the footer or places where the grass is green (we've been in a drought the past couple months).
    I replaced the toilet fill valve and flap as thought that might be a cause. Have looked at faucets to see if anything is dripping but nothing there. Only time I can har anything is when I put my ear up to shower wall and the house is very very quiet.
