    Springfield, VA
    Default Metal step drill
    I have a stepped bit for drilling through metal caps, but I can't find an extension tool that fits stepped bits that would allow me to drill though metal cross braces several feet down into a wall cavity. Whenever I encounter horizontal metal bracing, I have to place the outlet above the brace--too high to look good. I'm no good with drywall repair, so what to do?
    Midwest USA
    9
    Default Re: Metal step drill
    Do you have any sort of extender for this bit?
    I have hex backed hole saws and short (12") extenders. I took an extender to a machine shop and he was able to use the collar with set screw off it on a peice of bar stock (he milled the ends hex) to make me a 6' extender.
    Might be possible to take an existing extender and weld on a longer shaft.
    Your milage may vary.
    6,045
    What size is the shank on your step bit?
    Here are two extenders that will handle up to 3/8" shanks
    http://www.grizzly.com/products/H5943
    http://www.rockler.com/product.cfm?page=17994
