    Oct 2008
    Default Laminate flooring
    Hello
    Is it OK to install laminate on stairs and how is it done ?
    Thanks
    Default Re: Laminate flooring
    Yes you can install laminate to stair treads.
    You can use a quality parquet floor or construction adhesive to secure the laminate down to the treads.
    There will a need to also get a " nosing" to finish the edge of the treads. This will be fastened with a similar adhesive as above as well as a couple of screws.
    Follow the " essential installation guide for laminate flooring " in this link ....
    http://www.pergo.com/US_Install_Performance.aspx
    Hope this helps.
