    Mar 2010
    Default Refinishing Stairs
    What kind of power tool is recommended to refinish stained stairs? Would a multi-tool (like the dremel or rockwell) work better in the confined spaces rather than an orbit sander? I am afraid the smaller multi-tool will not sand evenly enough on the stair edges. Any recommendations on the correct tool to use?
    6,053
    Default Re: Refinishing Stairs
    I use an Random orbital sander and clean up the corners with a Rockwell oscillating tool.
