    Sep 2008
    Default help with dimmer switch
    light bulbs on high but dimmer switch does not control
    Denver, CO
    666
    Default Re: help with dimmer switch
    Will need a little more info to help you figure out what the problem is:
    1. Old dimmer, new dimmer?
    2. How many lamps and what type and wattage?
    3. Dimmer type and model number?
    6,061
    Also, is this the only switch that controls the lights?
    Shamokin, Pa.
    645
    If it does not dim, will it turn the light off?
    3-way setup ?
