Results 1 to 1 of 1
    1,890
    Default Reusing Interior Shutters
    In Amy R. Hughes' article Reusing Interior Shutters, (October 2008), I believe the wraparound hinges were installed incorrectly.
    By installing the hinges with the larger, wraparound leaf attached to the face of the cabinet frame and the smaller leaf attached to the edge of the door, the screws for the hinge will be concealed and you will be able to open the door a full 270 degrees, allowing the doors to fold flat against the side of the cabinet instead of sticking out to the side.
