Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Dec 2009
    MIchigan
    68
  2. #22
    980
    Default Re: Soundproofing basement ceiling
    message boards aren't proof.
  3. #23
    Dec 2009
    MIchigan
    68
    Quote Originally Posted by havanagranite View Post
    these posts are to give homeowners easy affordable solutions to their problems. That is what I am attempting to do not make it more complicated for them. if the instillation is done correctly, it is the fastest, easiest and most affordable. has a proven track record.
    The only proven track record is that 85% is installed incorrectly and has poor acoustic performance. Data is data. You're asserting your own logic and opinion as fact, when clearly it is not.
  4. #24
    Dec 2009
    MIchigan
    68
    The first 8 links are hard data from acoustic labs.
    The data is there, free and clear.
  5. #25
    980
    just going through the first one my question is whose point are you trying to prove mine or yours? it tells how good resilient channel works and how to properly install it to get the highest sound rating,.
  6. #26
    980
    Quote Originally Posted by Ted White View Post
    No one is forcing you to learn. The data is there, free and clear. If you decide not to act on it, that's your right, certainly.
    you need to read your own links first. and maybe you would learn
  7. #27
    Dec 2009
    MIchigan
    68
    It says how it's better than screwing the channel into the joists. No offense, but you'd need to read more on it more. There's a decade of data there that you're no one is going to assimilate in 15 minutes
  8. #28
    Dec 2009
    MIchigan
    68
    Have a nice evening
  9. #29
    980
    *** so if you can't prove it and you can't win in a debate then you must try to attack a person't intelligence? that is what most people do when the facts aren't on their side. what is your qualifications other then saying you are a consultant? you say you have worked in a lab? who was funding? because all your statments are biased. you are looking out for big money not for the homeowners pocket book, but maybe you would like to attack their intelligence also? and once again you never read your own link. I did.
    of course maybe it takes you longer to look at the pictures then other folks.
  10. #30
    980
    in all your links to the national research council Canada. I don't find any reference to your clips only to resilient channel as well as how when installed correctly how well it does.
    interestingly one of our engineers pointed out to me under the warrany information for some of your clips it said
    NO EXPRESS OR IMPLIED WARRANTIES
    THERE IS NO WARRANTY, REPRESENTATION OR CONDITION OF ANY KIND; AND ANY WARRANTY, EXPRESS OR IMPLIED,
    IS EXCLUDED AND DISCLAIMED, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND OF FITNESS FOR A
    PARTICULAR PURPOSE
    merchantable goods are goods fit for the ordinary purposes for which they are to be used
    so they won't even say that their own goods will perform as they should even if installed correctly.
    I also would like to know where you get your so called failure rating for resilient channel. for that was a big laugh at lunch with the architecte and the engineer on the job that we are currently working.
