    10
    Default Ideas/Design help for major improvement
    Hi everyone,
    I've been looking for design ideas for a major exterior renovation to the exterior of our home. Home is a brick ranch over a 1-car garage. There is an earthen-grade with a gravel driveway up/around to the main living area on the right of the house and a 6" concrete slab at the top of this grade that extends for 18 feet out of 43 feet total length of house front.
    The problem is, only half of the front entrance concrete slab is supported on a concrete-block foundation. The other half, as near as I can tell was laid on the dirt earthen grade and has started to sink on that portion of the slab causing a stress crack to develop in the slab about 2/3's the length of the concrete.
    I would like to remove the slab, excavate earthen mound bordering drive around (but preserving the drive around)install 1-car garage where earthen mound was (close off garage in main basement for living space - next project;-) and build a sunroom or a simple covered deck over the new garage.
    Does anyone know where I can get some ideas on design and construction of this type of project. Specifically, what are the alternatives to building materials for the 'roof' over the garage, which will be the floor for the deck/sunroom? I've considered replacing with poured concrete but that's probably going to be beyond our means for the size of this project. Alternatively, I've looked at some of the pre-formed roofing products that can be installed with a walkable surface on the top and there's also composite/wood decking.
    But I just really need some design ideas and comparisons.
    Sorry for the long post but thanks for the help.
    Gary
    Thumbs up Re: Ideas/Design help for major improvement
    Hi,
    You may consult the professional exterior designer who also have good knowledge of renovate the home within the range of affordability. You may also browse various websites related with the home improvement and renovation ideas. If you want to renovate the home without consultation of professional designer, get some magazines related with exterior desings and revamping home. It really gives you wonderful and inventive ideas for exclusive designation.
    Regards,
    Construct Hidden Content and Hidden Content in an innovative style.
    Default Re: Ideas/Design help for major improvement
    If you had sent a screen shot of your house, may be I could help you out a lot easier, plz do it if possible?
    Hi,
    First impressions are everything. And when entering a home the first thing seen is the door. A combination of exterior door replacement and interior door replacement is a quick way to give any home a new look and feel; without major structural changes, extensive construction, or cost.Door Replacement With a nearly infinite selection of style and types of doors available, one of the most difficult parts of the task is making the selection for a door installation project. Homeowners must consider what the main purpose is for door replacement; whether for style and appearance or functionality.Homeowners seeking to drastically alter the appearance of the main entry door of the home can choose from decorative fiberglass, metal or solid wood entry door designs. Many styles feature a decorative door window or side lights.Design features can add style and flair to any entrance, such as carved wood door or exterior French door options. Wood choices include maple, birch, mahogany, cherry or oak exterior door selections. Custom exterior door packages may include exotic wood options as well. Glass exterior sliding door choices are popular; especially for patio door or deck entry points. And more and more homeowners are opting for exterior double French door styles for the main entry or secondary entry points.
    costar has published article about Hidden Content and about his hotel in the new york cit
    Sep 2008
    Its very dangerous. Show any construction spe******t to discuss on this matter. My advice is you can use permanently bamboos and use any quality concrete to re build your roof.
    Sep 2008
    My suggest is that you must your roof to any spe******t. dear its very dangerous.
    Nov 2008
    7
    Im not sure what James is talking about but did you consider hiring an architect?
