    Sep 2008
    Question acroline window latches
    A few of our window latches are broken on our windows. The company's name is Acroline. I think that they might have gone out of business. The person who installed them is no longer in business so I have no way of contacting him. What can I do ?
    Default Re: acroline window latches
    You mean Euroline not Acroline??
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
    yep Acro Extrusion Corporation of Delaware makers of AcroLine Vinyl replacement windows went kaput.
    If you can't use a generic window latch think new insert windows.If the latch is your only problem consider yourself lucky, they went kaput for good reason!
