    Sep 2008
    Default Wallpaper on bathroom ceiling?
    Can I put wallpaper on a bathroom ceiling?
    2,009
    Default Re: Wallpaper on bathroom ceiling?
    Probably not a good idea given the moisture and condensation. I haven't had good luck with wallpaper on bathroom walls. I never tried it on a ceiling in any type of room. No doubt a pro could do it, but it never occurred to me to attempt it.
    Quote Originally Posted by shore_pk View Post
    Probably, but why would you want to? I can't imagine it would look good in addition to Ed's comments about moisture and humidity levels.
    6,063
    Yes you can. I have had paper on the walls and ceiling in our bathroom for over 16 years. Best to use plastic coated paper.
    Iowa
    7
    Yep, sure can! Talk to someone where you are ordering it and tell them your intended use so they can make sure you get the right glue and paper to stand up to the humidity. It's probably likely that some of the seams will pop, so be ready to go back and stick them back down again
    Read about my old house: Hidden Content
