    Sep 2008
    Default Seeking a level using water and plastic tubing
    I'm attempting to install a chair rail and I have an old house with no level floors. I remember watching recent episode of Ask TOH and Tom demonstrated how water and tubing was used to find a level. Can anyone refresh my memory?
    Thanks
    otienoja
    7,911
    Default Re: Seeking a level using water and plastic tubing
    It's called a water level. You have a vessel of water set at a fixed height. To that vessel you connect a length clear tubing. The other end of the tubing is connected to a story pole (yard stick ). The length of the tubing will depend on the distance you're trying to cover.
    Once everything is set up, start at one side and note the water level in the tubing, move along the length of the wall to find the high/low points, then determine where you wish to install your chair rail.
    IMHO, this isn't a necessary step for your chair rail because you want the rail to be a certain height from the floor, not necessarily perfectly level. To do so would draw attention to the unlevel floor with a "crooked" rail.
