    Sep 2008
    Default what is this tool???
    can anybody out there tell me what this tool is, I found it at a thrift store & could not pass it up. It is very heavy & has saw dust allover it so I figured one of you cats could help me out. Thanx Shawn
    7,160
    Default Re: what is this tool???
    It looks like the tooling head for a lathe, probably a metal lathe or mill.
    1,131
    I'm with Sprucey, basically.
    Tooling head for lathe, most likely. Sits on a movable platform/carriage perpendicular to the axis of the bed...and whatever tool is mounted in it...is advanced into the rotating stock mounted on the lathe.
    Or...could conceivably be the tailpiece from a lathe.
