    Default Crumbling brick on chimney
    Hello all, New to the board, and have a question.
    Our house was built in 1901, we purchased it 4 years ago. I noticed that the brick is getting "bubbles" that will break if touched, resulting in holes. The brick is very powdery when it bubbles out and if sc****d at in the holes.
    It looks as if the previous owners may have used a drylock type coating on it. The chimney is only used for the gas hot water heater, as their is not a firplace in the house, uncertain as if there ever was.
    What is the cause of this, and more importantly what can I do to fix it?
ID:	1621   Click image for larger version.
ID:	1622   Click image for larger version.
ID:	1623   Click image for larger version.
    Default Re: Crumbling brick on chimney
    I think I figured out what this is, would this be brick "spalling" and if it is I guess I have no choice but to replace what I can....
    http://www.usinspect.com/car/0204spalling.asp
    6,053
    You are most likely getting moisture behind the bricks. That can be from no cap or a damaged cap on the chimney, or condensation caused by inadequate draft for the hot water heater. A proper sized chimney liner and cap should help resolve the problem.
