    Sep 2008
    Bismarck, North Dakota
    9
    Default Shakey frame on slamming exterior door
    Our house is a small wood framed one story, one bedroom built in 1913. The front door was replaced with a Peachtree metal door by a carpenter about 15 years ago (the frame is about 32" X 80"). The door opens out into the porch because there isn't much swing space in the living room. When we shut (slam) the front door, the whole front wall from the door frame to the window next to it and above the door frame shakes. I pried off the bottom of the side moulding (a plinth?) nearer the window and hammered a long nail through the stud underneath into what I hoped was the plate below the door and that seemed to help a little. The wall still shakes, though, and rattles pictures hanging on the wall and even the porch light on the outside of the wall next to the door. The ceilings are 9-feet high and all the old plaster and lath of the walls was replaced about 20 years ago with sheetrock. The ceiling sheetrock is over the lath, if I remember right. The attic is directly above the ceiling over the door, and the ceiling is about 27 inches above the top of the door. I'm hoping for suggestions on how to get the wall to stop shaking.
    Sep 2008
    9
    Default Re: Shakey frame on slamming exterior door
    I'll answer my own post. I tried to post this a couple of days ago, but I don't see the reply, so will try again.
    From the outside of the house, I drilled holes through the thin part of the lap siding, then through the 3/4-inch sheathing board below and into the studs above and next to the door frame and then ran 3 and 3/4-inch decking screws into the studs. I did this for perhaps five lap siding pieces per stud. This seemed to improve the wall and door frame stability. I'll eventually fill the holes with caulk or plaster and paint.
