    Sep 2008
    Unhappy Tankless Water Heater
    Hi List,
    I've got a Bosch tankless water heater that I'm having a little trouble with. I was using the water heater and got the flow running a little too low for its taste so it stopped heating the water and went into an error mode. I've tried the reset process numerous times, but it won't reset and start working again. It thinks it has no gas according to the error code, but that certainly isn't true...
    Has anyone else run into this?
    Thanks,
    Bryan
    Memphis, not Egypt
    183
    Default Re: Tankless Water Heater
    Does the unit run a self diagniostic? What does the manual say?
